Introduzione
The drive motor is held down with only two screws and can be easily removed and replaced.
Cosa ti serve
Remove all attachments: water tank, drip tray, aroma lid
Behind the Jura sign are two screws with an oval head. They have to be removed.
These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
This step shows how to remove the top cover
Remove the powder tray and all coffee beans.
The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
Remove the two Phillips screws on the bean container and remove the bean container.
Lift the cover upwards.
The drive motor is fastened with two Torx T20 screws.
Remove the two screws.
Take out the motor
The encoder that counts the revolutions is located on the motor shaft. Disconnect the plug from the encoder
Work through the steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
shingle ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
