Introduzione
Your fully automatic coffee machine makes very loud noises when grinding the coffee beans?
When making coffee, does the coffee only come out in drips?
Then you may have a problem with the grinder of your Jura Impressa F50 fully automatic coffee machine.
These instructions are intended to help you get access to the grinder of your fully automatic coffee machine in order to service it or to replace it completely.
It consists of a total of 3 parts: opening the machine, removing the grinder and reassembly.
Cosa ti serve
Remove the drip pan, tray and container for used coffee,...
... the water tank, ...
and the aroma protection cover.
Remove the lock washer on the axle for grinding degree adjustment using pliers.
Altre 6 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
