Salta al contenuto principale
Jura Impressa C E F models grindstone replacement
  1. Jura Impressa C E F models grindstone replacement, Jura Impressa C E F models grindstone replacement: passo 1, immagine 1 di 1
    • The instructions apply to almost all devices from Jura and similar devices from AEG, Krups. The success of the repair is striking!
    • The picture shows the old grind stones on the left and the new ones on the right. They consist of a grinding ring and a grinding cone.
    • For this repair, the side parts do not necessarily have to be removed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Jura Impressa C E F models grindstone replacement: passo 2, immagine 1 di 2 Jura Impressa C E F models grindstone replacement: passo 2, immagine 2 di 2
    • Pull the grinder adjuster up. Note the setting, it is best to take a photo of it.
    • The screws that hold the coffee container are located in two recesses. First clean, then loosen. The protective cover over the grinder does not need to be removed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Follow the steps in reverse order to reassemble your device
Un ringraziamento speciale a questi traduttori:
de en
100%
oldturkey03 ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
336.029 Reputazione
311 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 40
Tutti i Tempi: 820
