Salta al contenuto principale
Jura Grindstone Replacement
Cosa ti serve
  1. Jura Grindstone Replacement, Removing The Grinder Ring: passo 1, immagine 1 di 3 Jura Grindstone Replacement, Removing The Grinder Ring: passo 1, immagine 2 di 3 Jura Grindstone Replacement, Removing The Grinder Ring: passo 1, immagine 3 di 3
    • Now the grinder is free. Again take a picture, then pull out the axis of the adjuster with moderate force.
    • This adjuster may not be present on some models.
    • Depending on the model you will find a silicon sealing on top of the grinder ring, remove it.
    • Watch the fabrication signs , here green. This alignment must be restored later. Now turn the great black gear about 90 degrees counterclockwise. The grinder ring is free and can be lifted off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Jura Grindstone Replacement, The Grinder Cone: passo 2, immagine 1 di 3 Jura Grindstone Replacement, The Grinder Cone: passo 2, immagine 2 di 3 Jura Grindstone Replacement, The Grinder Cone: passo 2, immagine 3 di 3
    • In the next step be very careful not to loose these three springs, balls and cartridges.
    • The grinding cone is fastened with a long Torx T20 screw. The screw head is often covered with remnants of coffee beans. Expose the head and turn the screw out counterclockwise.
    • Now the bean feeder (the small white snail) can be removed. The grinder cone and drive can now also be lifted up carefully.
    Chiedi a FixBot
    Aggiungi Commento
  3. Jura Grindstone Replacement, Cleaning: passo 3, immagine 1 di 2 Jura Grindstone Replacement, Cleaning: passo 3, immagine 2 di 2
    • The grinder is usually filled with old, sticky coffee grounds. Clean everything carefully for an excellent coffee aroma.
    • Gently lift the felt ring around the drive shaft with a needle, then wipe it clean with a damp cloth. Do not attempt to wash it, as there is a risk that it will swell. When first used, turn it over with the clean side up.
    • Clean the inside of the grinder with a brush and damp cloth, and the blades with a dishwashing brush. Ensure it is properly dried before use.
    Chiedi a FixBot
    Aggiungi Commento
  4. Jura Grindstone Replacement, Change The Grinder Ring: passo 4, immagine 1 di 3 Jura Grindstone Replacement, Change The Grinder Ring: passo 4, immagine 2 di 3 Jura Grindstone Replacement, Change The Grinder Ring: passo 4, immagine 3 di 3
    • Push both of the small latches alternately. Then the ring cover should come out.
    • Two clamps hold the grinder ring in its place, push them aside and it should come free.
    • Again clean everything. Press the new ring and cover in its place. With that the grinder ring is exchanged.
    Chiedi a FixBot
    Aggiungi Commento
  5. Jura Grindstone Replacement, Change The Grinder Cone: passo 5, immagine 1 di 1
    • First insert the cleaned driver, then the three sleeves, springs and balls. Now fit the grinding cone on the three balls.
    • Then fit the auger, screw in central screws. When screwing in, push the cone downwards and make sure that everything meshes.
    • This screw turns into plastic. If it doesn't fit properly, the thread will be damaged. So first turn the screw counterclockwise until you feel that the first thread is engaged. Then tighten it turning clockwise.
    Chiedi a FixBot
    Aggiungi Commento
  6. Jura Grindstone Replacement, Reassembling: passo 6, immagine 1 di 1
    • Insert grinding ring. The black gear is turned to the right again until the three marks are aligned. Then reinstall the adjuster drive shaft as it was originally.
    • The adjustment oft the new grinder burrs musst not necessarily be the same as the old ones. You can approximately find the mean position, which was marked before, by turning the outer ring as far as possible clockwise, then turning it fourteen clicks backwards.
    • It is a good idea to check if the grinder rotates freely. You can remove the meal hopper and look at the millstones from the side.
    • Then install the remaining parts in reverse order.
    • You can set the grinding degree nicely by placing an empty roll of toilet paper perpendicular to the open mill and filling it with a few coffee beans. Plug in the plug (be careful!), choose a cup of coffee and watch as the coffee grounds fall out of the grinder.
    Chiedi a FixBot
    Aggiungi Commento
  7. Jura Grindstone Replacement, Before - After: passo 7, immagine 1 di 2 Jura Grindstone Replacement, Before - After: passo 7, immagine 2 di 2
    • These two pictures are no fake: Before repairing the grinder the coffee is thin and transparent. With new stones the coffee is strong and has a fine crema. The repair was a real success!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Now follow the remaining steps in reverse direction to reassemble your device.
Altre 13 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
335.299 Reputazione
311 guide realizzate
26Commenti sulla guida
Thank you for the guide. I have FILL BEANS error, I followed this guide. No problem. But with new burrs, I still have FILL BEANS error. Any idea why? My burrs were not so bad. I only have 2000 espressos on the counter.
jimmylasvegas - Rispondi Condividi
Which model of Jura is it?
VauWeh - Rispondi Condividi
Z5, first generation
So my guess is the “Fill-Bean-Sensor", consisting in an infrared LED and a photocell. You can see it in the bean funnel on top of the mill. Perhaps you disconnected it while ?
The fame “fill beans” error is that not enough coffee is entering the brewgroup. I have cleaned the grinder and the chute to the brewgroup. Grinder spins fast. But very little coffee actually go down into the grinder. I have watched several youtube videos on grinder calibration. But no idea. If you use the 2 big espresso cup button, then no error because the grinder runs a longer time. But still not enough coffee for 2 large cups. Just no error.
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 69
Ultimi 30 giorni: 369
Tutti i Tempi: 53,426
