Introduzione
The water tank and the coffee machine are sealed against each other with two gaskets. One (an O-Ring) is located in the water tank and ensures that no water leaks out when the tank is removed for filling. If it leaks, water will drip out during filling. It may be a little uncomfortable, but is not particularly bad. Replacing it is a bit tricky, but almost self-explanatory. The other gasket surrounds the water connection in the device. When it leaks, water drips out constantly, there are lime marks or even small puddles under the device. To replace it, you need to know the trick, this is shown here.
Cosa ti serve
Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
Remove all coffee beans.
Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
Lay the machine on its side.
Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
In the same way, insert another opening pick on the opposite edge.
The first picture shows the already removed holder and the seal. The next steps will show you how to get it out.
Remove the three Torx T15 screws that secure the electronics box.
Lift the box a little to the side so that the pump can be removed. The connection cables can all remain connected.
Pull out the metal clamp at the upper pump outlet.
Pull out the diaphragm damper above the pump, the hose can remain connected. Pay attention to the gasket, it is best to replace it.
Now you can clearly see how the silicone hose leads to the holder for the seal of the water connection. The holder must be turned about 45 degrees, then it can be taken out downwards. The rear end of the holder is secured by a detent and must be turned towards you.
Push the detent away a little and twist the holder.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
