Introduzione
You will need knowledge of how to use a soldering iron station. For more information regarding soldering visit: Soldering Skills During the replacement of the volume knob, you will unscrew the knob from the motherboard. After removing the screw you will then need to unsolder the rest of the knob from the motherboard.
Cosa ti serve
Access the battery compartment
Remove the battery compartment lid and set it aside.
Disconnect the battery and set it aside.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the white glue on the volume knob by peeling it off or gently using tweezers to pull it out.
Allow approximately 10 minutes for the soldering station to heat up before using.
