Salta al contenuto principale
Jumper Angelsounds JPD-100S Motherboard Replacement
Cosa ti serve
  1. Jumper Angelsounds JPD-100S Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Motherboard Replacement: passo 2, immagine 1 di 2 Jumper Angelsounds JPD-100S Motherboard Replacement: passo 2, immagine 2 di 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Motherboard Replacement: passo 4, immagine 1 di 2 Jumper Angelsounds JPD-100S Motherboard Replacement: passo 4, immagine 2 di 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Motherboard Replacement: passo 5, immagine 1 di 2 Jumper Angelsounds JPD-100S Motherboard Replacement: passo 5, immagine 2 di 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Motherboard Replacement: passo 6, immagine 1 di 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
Linea Traguardo
USF Tampa, Team 6-1, Remmell Fall 2015 Membro di USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
6 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 277
