Salta al contenuto principale
Jensen JTA-230 Turntable Platter Replacement
Cosa ti serve
  1. Jensen JTA-230 Turntable Platter Replacement, Turntable Platter: passo 1, immagine 1 di 1
    • Remove Cover from record player.
  2. Jensen JTA-230 Turntable Platter Replacement: passo 2, immagine 1 di 1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Turntable Platter Replacement: passo 3, immagine 1 di 1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Turntable Platter Replacement: passo 4, immagine 1 di 1
    • Replace rubber plugs
  5. Jensen JTA-230 Turntable Platter Replacement: passo 5, immagine 1 di 1
    • Replace Cover
Conclusione
Robert Wilcox
Membro da: 03/04/16
227 Reputazione
2 Guide realizzate
Un commento
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
ironman175 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,682
