Salta al contenuto principale
Jazz UltraTab C1059-HL Speaker Replacement
Cosa ti serve
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: passo 2, immagine 1 di 1
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: passo 3, immagine 1 di 1
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: passo 4, immagine 1 di 1
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: passo 5, immagine 1 di 1
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
Conclusione
Tim Poe
Membro da: 09/26/15
361 Reputazione
3 Guide realizzate
IUPUI, Team 1-3, Wilson Fall 2015 Membro di IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 89
