Salta al contenuto principale
Jazz UltraTab C1059-HL Headphone Jack Replacement
Cosa ti serve
  1. Jazz UltraTab C1059-HL Headphone Jack  Replacement, Headphone Jack: passo 1, immagine 1 di 1
    • Use a Philips screwdriver to remove the four screws: two at the top and two at the bottom of the device.
  2. Jazz UltraTab C1059-HL Headphone Jack  Replacement: passo 2, immagine 1 di 2 Jazz UltraTab C1059-HL Headphone Jack  Replacement: passo 2, immagine 2 di 2
    • Place the device screen down on the table and use a pry tool to remove the back panel.
  3. Jazz UltraTab C1059-HL Headphone Jack  Replacement: passo 3, immagine 1 di 1
    • For your safety, remove the battery.
    • Using a solder iron, remove the wires connecting the battery to the motherboard.
  4. Jazz UltraTab C1059-HL Headphone Jack  Replacement: passo 4, immagine 1 di 2 Jazz UltraTab C1059-HL Headphone Jack  Replacement: passo 4, immagine 2 di 2
    • Remove the screw attaching the motherboard to the back panel. Gently remove the motherboard.
  5. Jazz UltraTab C1059-HL Headphone Jack  Replacement: passo 5, immagine 1 di 1
    • The headphone jack is attached to the motherboard, so the whole thing must be replaced.
    • With the new mother board, use these steps in reverse to reassemble the device.
Conclusione
Tim Poe
Membro da: 09/26/15
361 Reputazione
3 Guide realizzate
IUPUI, Team 1-3, Wilson Fall 2015 Membro di IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 100
