Salta al contenuto principale
Jazz UltraTab C1059-HL Battery Replacement
Cosa ti serve
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: passo 1, immagine 1 di 1
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: passo 2, immagine 1 di 2 Jazz UltraTab C1059-HL Battery Replacement: passo 2, immagine 2 di 2
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: passo 3, immagine 1 di 1
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: passo 4, immagine 1 di 2 Jazz UltraTab C1059-HL Battery Replacement: passo 4, immagine 2 di 2
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: passo 5, immagine 1 di 1
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
Conclusione
IUPUI, Team 1-3, Wilson Fall 2015 Membro di IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 591
