Salta al contenuto principale
Jawbone MINI JAMBOX Side Button Assembly Replacement
Cosa ti serve
  1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: passo 1, immagine 1 di 2 Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: passo 1, immagine 2 di 2
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
    Chiedi a FixBot
  2. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 2, immagine 1 di 1
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
    Chiedi a FixBot
  3. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 3, immagine 1 di 1
    • Slide out the rubber foot located on the bottom of the case.
    Chiedi a FixBot
  4. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 4, immagine 1 di 1
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
    Chiedi a FixBot
  5. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 5, immagine 1 di 3 Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 5, immagine 2 di 3 Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 5, immagine 3 di 3
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
    Chiedi a FixBot
  6. Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: passo 6, immagine 1 di 2 Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: passo 6, immagine 2 di 2
    • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
    Chiedi a FixBot
  7. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 7, immagine 1 di 1
    • Using the standard metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
    • It should come off after prying up the first tab.
    Chiedi a FixBot
  8. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 8, immagine 1 di 3 Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 8, immagine 2 di 3 Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 8, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Carefully lift out the end panel.
    • Unplug both the connection ribbon and the ZIF or "zero insertion force" ribbon using tweezers or your hands.
    • There is a bit of glue to hold the connection ribbon down.
    Chiedi a FixBot
  9. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 9, immagine 1 di 1
    • Using the spudger, push the button in and create a small gap between the outside structure and the button.
    Chiedi a FixBot
  10. Jawbone MINI JAMBOX Side Button Assembly Replacement: passo 10, immagine 1 di 1
    • Using a computer duster, blow any contaminants out from the button junction.
    • Using a q-tip and cleaner, wipe off any stickiness from the buttons, ensuring to prevent excessive moisture.
    • Alternate Reassembly required, read on.
    Chiedi a FixBot
Conclusione
To reassemble your device, follow steps 1 through 5 in reverse order.
Cal Poly, Team 12-1, Lancaster Spring 2015 Membro di Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Membri
11 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 61
Tutti i Tempi: 1,123
