Salta al contenuto principale
Jam XT HX-P430 Disassembly
Cosa ti serve
  1. Jam XT HX-P430 Disassembly, Casing: passo 1, immagine 1 di 1
    • You can really take this off however you want but here's a pic.
  2. Jam XT HX-P430 Disassembly, Speaker Guard: passo 2, immagine 1 di 3 Jam XT HX-P430 Disassembly, Speaker Guard: passo 2, immagine 2 di 3 Jam XT HX-P430 Disassembly, Speaker Guard: passo 2, immagine 3 di 3
    • Using a spudger or similar pry the guard off one side at a time.
  3. Jam XT HX-P430 Disassembly, Screws!: passo 3, immagine 1 di 2 Jam XT HX-P430 Disassembly, Screws!: passo 3, immagine 2 di 2
    • Remove the screws for the speaker and the four that are down the holes.
    • It isn't necessary but I removed the d-ring as well.
  4. Jam XT HX-P430 Disassembly, Case: passo 4, immagine 1 di 3 Jam XT HX-P430 Disassembly, Case: passo 4, immagine 2 di 3 Jam XT HX-P430 Disassembly, Case: passo 4, immagine 3 di 3
    • Remove the black button spacers. (Note: There are 3 spacers I lost one).
    • Push the white bottom through the hole and slowly wiggle the blue case off. Be careful not to break the speaker cables.
    • Now remove the four screws.
  5. Jam XT HX-P430 Disassembly, Board and Battery.: passo 5, immagine 1 di 3 Jam XT HX-P430 Disassembly, Board and Battery.: passo 5, immagine 2 di 3 Jam XT HX-P430 Disassembly, Board and Battery.: passo 5, immagine 3 di 3
    • They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together.
    • Carefully using a knife try to split the silicone so the connectors come off easily.
    • Next remove the fours screws holding the board in. (Note: There is two matching pairs.)
    • Using the spudger remove the battery from the white plastic.
  6. Jam XT HX-P430 Disassembly, Finished!: passo 6, immagine 1 di 2 Jam XT HX-P430 Disassembly, Finished!: passo 6, immagine 2 di 2
    • Yay! It is disassembled.
    • (Note: There are 3 spacers I lost one).
Conclusione
Wolf Andrew
Membro da: 03/19/18
133 Reputazione
1 Guida realizzata
Un commento
Is the amp bridgable ?
jonathan s - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 801
