Salta al contenuto principale
Jam Voice Battery Replacement
Cosa ti serve
  1. Jam Voice Battery Replacement, Hard Mesh Cover: passo 1, immagine 1 di 2 Jam Voice Battery Replacement, Hard Mesh Cover: passo 1, immagine 2 di 2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Battery Replacement, Motherboard: passo 2, immagine 1 di 1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Battery Replacement: passo 3, immagine 1 di 2 Jam Voice Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Battery Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Battery Replacement: passo 5, immagine 1 di 3 Jam Voice Battery Replacement: passo 5, immagine 2 di 3 Jam Voice Battery Replacement: passo 5, immagine 3 di 3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Battery Replacement: passo 6, immagine 1 di 1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Battery Replacement: passo 7, immagine 1 di 2 Jam Voice Battery Replacement: passo 7, immagine 2 di 2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
  8. Jam Voice Battery Replacement, Battery: passo 8, immagine 1 di 3 Jam Voice Battery Replacement, Battery: passo 8, immagine 2 di 3 Jam Voice Battery Replacement, Battery: passo 8, immagine 3 di 3
    • Expose the motherboard and battery and place in a position that will be easy to access and work with.
    • Use tweezers to remove the battery's wire from the motherboard at the connection point.
    • The battery's connection point is opposite the speaker's connection point.
    • Pull the battery from the motherboard.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 30
Tutti i Tempi: 797
