Salta al contenuto principale
Jabra CRUISER2 Speaker Replacement
Cosa ti serve
  1. Jabra CRUISER2 Speaker Replacement, Front Plate: passo 1, immagine 1 di 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Istruzioni iOpener
  2. Jabra CRUISER2 Speaker Replacement: passo 2, immagine 1 di 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Speaker Replacement: passo 3, immagine 1 di 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Speaker Replacement, Speaker: passo 4, immagine 1 di 2 Jabra CRUISER2 Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  5. Jabra CRUISER2 Speaker Replacement: passo 5, immagine 1 di 1
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  6. Jabra CRUISER2 Speaker Replacement: passo 6, immagine 1 di 1
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  7. Jabra CRUISER2 Speaker Replacement: passo 7, immagine 1 di 2 Jabra CRUISER2 Speaker Replacement: passo 7, immagine 2 di 2
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
Conclusione
Spartacus
Membro da: 10/17/14
636 Reputazione
5 Guide realizzate
Baylor, Team 8-13, Williams Fall 2014 Membro di Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Membri
5 Guide realizzate
5 Commenti
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - Replica
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - Replica
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
A 36 mm speaker will also fit nicely. A 1 watt 8 ohms speaker is the best choice - the amplifier is not able to output enough power to drive a 2+ watt speaker.
Mobi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,886
