Salta al contenuto principale
JYX-S55 Speaker Replacement
Cosa ti serve
  1. JYX-S55 Speaker Replacement, Speaker: passo 1, immagine 1 di 2 JYX-S55 Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Remove the four screws from the top panel of the device using a 2.5 hex screwdriver.
    • Remove the top panel.
  2. JYX-S55 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the four screws that keep the light strip in place using a JIS #1 screwdriver.
  3. JYX-S55 Speaker Replacement: passo 3, immagine 1 di 2 JYX-S55 Speaker Replacement: passo 3, immagine 2 di 2
    • Lift out the plastic ring which contains the lights.
    • The lights will be connected with wires. These do not need to be cut or ripped out; simply place the plastic ring off to the side or somewhere out of the way.
  4. JYX-S55 Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the four screws at the corners of the woofer/speaker using a JIS #1 screwdriver.
  5. JYX-S55 Speaker Replacement: passo 5, immagine 1 di 1
    • Pull out the speaker’s woofer.
  6. JYX-S55 Speaker Replacement: passo 6, immagine 1 di 2 JYX-S55 Speaker Replacement: passo 6, immagine 2 di 2
    • Use a pair of wire cutters to separate the speaker from the rest of the device.
Conclusione
Marist, Team 1-5, Chaterdon Spring 2023 Membro di Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 440
