Introduzione
These LED lights can burn out from use. If dropped sometimes the housing is not enough to protect the bulbs. To remove it you will need a Phillips #000 screwdriver, small plastic opener, and small metal spudger.
This guide requires removing a lot of screws so it is important to keep track of which screw goes where. All screw heads are Phillips size #000.
Cosa ti serve
Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
Remove the 3.1 mm screw.
Remove the three 5.3 mm screws from the back of the camera.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
Insert the cables from the new port panel into their inputs and flip the locks to the down position.
From the inside of the camera remove these six screws.
3.3 mm
3.6 mm
3.1 mm
4.3 mm
4.3 mm
3.7 mm
Remove the three screws securing the microphone housing and camera operation buttons to the frame with the following sizes:
4.3 mm
3.1 mm
4.2 mm
Open the cassette holder to reveal a 2.4 mm screw on the bottom of the camera and remove it.
Make sure the camera operation buttons are positioned completely outside of the camera frame.
Gently lift the microphone housing from the front-bottom side of the camera and remove it from the frame.
