Introduzione
Some of the mechanical parts in the cassette holder can come loose or become damaged. To remove it you will need a Phillips #000 screwdriver, small plastic opener, and small metal spudger.
This guide requires removing a lot of screws so it is important to keep track of which screw goes where. All screw heads are Phillips size #000.
Cosa ti serve
Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
Remove the 3.1 mm screw.
Remove the three 5.3 mm screws from the back of the camera.
From the inside of the camera remove these six screws.
3.3 mm
3.6 mm
3.1 mm
4.3 mm
4.3 mm
3.7 mm
