Introduzione
To complete this guide, you will need to purchase a new external lens and make sure that you have the tools listed. It is always good practice to make sure that the device is completely powered off and remove the battery before attempting any repairs.
Cosa ti serve
Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
Conclusione
