Salta al contenuto principale
JVC Adixxion GC-XA1BU LCD Screen Replacement
Cosa ti serve
  1. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 2, immagine 1 di 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 3, immagine 1 di 1
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 4, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 4, immagine 2 di 2
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery Cover: passo 6, immagine 1 di 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: passo 7, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: passo 7, immagine 2 di 2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 8, immagine 1 di 1
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 9, immagine 1 di 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 9, immagine 2 di 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 9, immagine 3 di 3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 10, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 10, immagine 2 di 2
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 11, immagine 1 di 1
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 12, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 12, immagine 2 di 2
    • Carefully pull the white clip out of the casing using the tweezers.
  13. JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: passo 13, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: passo 13, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
  14. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 14, immagine 1 di 1
    • Once you have lifted and removed the silver plate, use a Phillips #00 screwdriver to remove the two bottom screws (4mm x 3mm).
  15. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 15, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 15, immagine 2 di 2
    • Using Tweezers, gently pull the red, black, and white threaded wire to disconnect it, then remove the attached panel as shown.
  16. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: passo 16, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: passo 16, immagine 2 di 2
    • Carefully lift up and remove the LCD screen using the tweezers.
  17. JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 17, immagine 1 di 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: passo 17, immagine 2 di 2
    • The screen as shown if removed properly.
Conclusione
Follow these steps in reverse order with the new LCD screen in order to complete the replacement.
USF Tampa, Team 1-2, Tanski Winter 2015 Membro di USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 785
