Introduzione
The T-Bar allows you to steer and control your scooter. This guide will show the replacement of a T-Bar.
Cosa ti serve
Unlock the quick-release lever by turning the lever from a tightened position.
Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
Be sure to fasten the opposite side of the screw before unscrewing.
Turn the quick-release lever over to reveal an 8mm screw.
Use the Phillips #2 screw driver to remove the screw.
After removing the screw, the circular latch will be detachable.
After disassembling the Quick-Release Lever, the T-Bar is removable
