Salta al contenuto principale
JD Razor 2000 Quick-Release Lever Replacement
Cosa ti serve
  1. JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: passo 1, immagine 1 di 2 JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: passo 1, immagine 2 di 2
    • Unlock the quick-release lever by turning the lever from a tightened position.
  2. JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: passo 2, immagine 1 di 3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: passo 2, immagine 2 di 3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: passo 2, immagine 3 di 3
    • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
    • Be sure to fasten the opposite side of the screw before unscrewing.
    • Remove the screw and note the order of the parts for reassembly.
  3. JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: passo 3, immagine 1 di 3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: passo 3, immagine 2 di 3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: passo 3, immagine 3 di 3
    • Turn the quick-release lever over to reveal an 8mm screw.
    • Use the Phillips #2 screw driver to remove the screw.
    • After removing the screw, the circular latch will be detachable.
Conclusione
Shane
Membro da: 10/18/14
384 Reputazione
3 Guide realizzate
Cal Poly, Team 4-46, Amido Fall 2014 Membro di Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,404
