Salta al contenuto principale
JD Razor 2000 Handle Bar Replacement
Cosa ti serve
  1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: passo 1, immagine 1 di 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: passo 1, immagine 2 di 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: passo 1, immagine 3 di 3
    • Firmly hold the handle bar in place.
    • Grab with one hand the black removable tip of the handle bar and pull it out.
    • Pull out the end of the tied string through the removable tip.
    Chiedi a FixBot
    Aggiungi Commento
  2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: passo 2, immagine 1 di 2 JD Razor 2000 Handle Bar Replacement, Untying the Knot: passo 2, immagine 2 di 2
    • Untie the knot at the end of the string.
    • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
    Chiedi a FixBot
    Aggiungi Commento
  3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: passo 3, immagine 1 di 2 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: passo 3, immagine 2 di 2
    • Press down firmly on the golden fastening button located on the handle bar being replaced.
    • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
    • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-46, Amido Fall 2014 Membro di Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Membri
16 guide realizzate
3Commenti sulla guida
Why is the stretchable string for?
dantotford - Rispondi Condividi
Where can I buy a wider set of click in handlebars?
Scooterdad - Rispondi Condividi
I'm also looking for a JD BUG replacement handlebar, I mean the horizontal parts.
Mon Drianus - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 59
Tutti i Tempi: 2,883
