Introduzione
This guide will show you how to remove a bass radiator from a JBL Xtreme Speaker. Removing these radiators is required if they become damaged and will also be necessary to access certain components inside the speaker.
Cosa ti serve
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
Altre 12 persone hanno completato questa guida.
