Salta al contenuto principale
JBL Xtreme 3 Tweeters Replacement
Cosa ti serve
  1. JBL Xtreme 3 Tweeters Replacement, Exterior Speaker Shell Cover: passo 1, immagine 1 di 1
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Tweeters Replacement: passo 2, immagine 1 di 1
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Tweeters Replacement: passo 3, immagine 1 di 2 JBL Xtreme 3 Tweeters Replacement: passo 3, immagine 2 di 2
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 Tweeters Replacement, Tweeters: passo 4, immagine 1 di 1
    • Carefully turn the JBL devices on its side
    • Locate the 4 screws connecting the piece of hardware containing the tweeters and the piece of hardware containing the motherboard.
    • With a Phillip Screwdriver unscrew those 4 screws
  5. JBL Xtreme 3 Tweeters Replacement: passo 5, immagine 1 di 1
    • With the Sharp end of the Spudger
  6. JBL Xtreme 3 Tweeters Replacement: passo 6, immagine 1 di 1
    • Repeat steps 1 and 2 on the other side of the JBL Device
Conclusione
IUPUI, Team 2-5, Harley Fall 2023 Membro di IUPUI, Team 2-5, Harley Fall 2023
IUPUI-HARLEY-F23S2G5
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 235
