Salta al contenuto principale
JBL Xtreme 3 Buttons Replacement
Cosa ti serve
  1. JBL Xtreme 3 Buttons Replacement, Exterior Speaker Shell Cover: passo 1, immagine 1 di 1
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Buttons Replacement: passo 2, immagine 1 di 1
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Buttons Replacement: passo 3, immagine 1 di 2 JBL Xtreme 3 Buttons Replacement: passo 3, immagine 2 di 2
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 Buttons Replacement, Buttons: passo 4, immagine 1 di 1
    • Wedge the spudger between the outer button cover and the speaker hardware.
    • Gently push down on the spudger, lifting the outer button cover away from the device.
    • To much pressure going inward could puncture the inner button Panel.
    • Repeat this on the left side of the Button cover.
  5. JBL Xtreme 3 Buttons Replacement: passo 5, immagine 1 di 1
    • Once the left and right sides of the outer button cover are released. Slightly move the spudger around the outer cover and push down on the spudger.
    • Repeat this until the the out cover is no longer attached to the device.
    • All you should see is the inner button panel.
  6. JBL Xtreme 3 Buttons Replacement: passo 6, immagine 1 di 1
    • With the inner button panel exposed place the spudger directly under the inner panel and gently push on the spudger.
    • Repeat the last steps all the way around the inner panel.
Conclusione
IUPUI, Team 2-5, Harley Fall 2023 Membro di IUPUI, Team 2-5, Harley Fall 2023
IUPUI-HARLEY-F23S2G5
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 212
