Introduzione
If the battery in your JBL Xtreme 3 (JBLXTREME3BLKAM) portable Bluetooth speaker is failing or has completely died, this guide will instruct you on replacing the battery.
Please review information about proper battery disposal.
Warning: Please take precautions if you suspect a swollen battery.
Cosa ti serve
Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
Use your hands to finish removing the outer case of the device.
Altre 5 persone hanno completato questa guida.
