Introduzione
This guide shows you how to remove the bottom plate, this provides access to the subwoofer itself.
Cosa ti serve
Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
With all three loosened remove the base!
Note the not equilateral placement of the risers when replacing the base.
Altre 17 persone hanno completato questa guida.
12 Commenti
No problem!!
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
