Salta al contenuto principale
JBL Spyro/Spot Partial Disassembly
Cosa ti serve
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: passo 1, immagine 1 di 1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: passo 2, immagine 1 di 1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: passo 3, immagine 1 di 1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
Conclusione
Altre 17 persone hanno completato questa guida.
Ryan McLeod
Membro da: 05/22/10
606 Reputazione
2 Guide realizzate
11 Commenti
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Replica
No problem!!
Ryan McLeod -
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Replica
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 107
Tutti i Tempi: 13,050
