Salta al contenuto principale
JBL Pulse Speakers Replacement
Cosa ti serve
  1. JBL Pulse Speakers Replacement, Button Board: passo 1, immagine 1 di 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Speakers Replacement: passo 2, immagine 1 di 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Speakers Replacement: passo 3, immagine 1 di 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Speakers Replacement: passo 4, immagine 1 di 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Speakers Replacement: passo 5, immagine 1 di 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Speakers Replacement, Outer Casing: passo 6, immagine 1 di 3 JBL Pulse Speakers Replacement, Outer Casing: passo 6, immagine 2 di 3 JBL Pulse Speakers Replacement, Outer Casing: passo 6, immagine 3 di 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: passo 7, immagine 1 di 2 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: passo 7, immagine 2 di 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: passo 8, immagine 1 di 1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Speakers Replacement: passo 9, immagine 1 di 3 JBL Pulse Speakers Replacement: passo 9, immagine 2 di 3 JBL Pulse Speakers Replacement: passo 9, immagine 3 di 3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Speakers Replacement: passo 10, immagine 1 di 2 JBL Pulse Speakers Replacement: passo 10, immagine 2 di 2
    • Remove cables by pulling firmly.
  11. JBL Pulse Speakers Replacement, Speakers: passo 11, immagine 1 di 2 JBL Pulse Speakers Replacement, Speakers: passo 11, immagine 2 di 2
    • Remove four black PH0 9mm screws.
    • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
    • New speakers will have to be re-soldered to these wires.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 18-6, Blackwell Fall 2016 Membro di USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Membri
8 Guide realizzate
8 Commenti
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - Replica
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - Replica
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
what is the speaker specification that I can buy for replacement?
rbalagr - Replica
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 55
Tutti i Tempi: 7,358
