Salta al contenuto principale
JBL Pulse Outer Casing Replacement
Cosa ti serve
  1. JBL Pulse Outer Casing Replacement, Button Board: passo 1, immagine 1 di 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Outer Casing Replacement: passo 2, immagine 1 di 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Outer Casing Replacement: passo 3, immagine 1 di 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Outer Casing Replacement: passo 4, immagine 1 di 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Outer Casing Replacement: passo 5, immagine 1 di 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Outer Casing Replacement, Outer Casing: passo 6, immagine 1 di 3 JBL Pulse Outer Casing Replacement, Outer Casing: passo 6, immagine 2 di 3 JBL Pulse Outer Casing Replacement, Outer Casing: passo 6, immagine 3 di 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 18-6, Blackwell Fall 2016 Membro di USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,565
