Salta al contenuto principale
JBL Pulse LED Light Replacement
Cosa ti serve
  1. JBL Pulse LED Light Replacement, Button Board: passo 1, immagine 1 di 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse LED Light Replacement: passo 2, immagine 1 di 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse LED Light Replacement: passo 3, immagine 1 di 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse LED Light Replacement: passo 4, immagine 1 di 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse LED Light Replacement: passo 5, immagine 1 di 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse LED Light Replacement, Outer Casing: passo 6, immagine 1 di 3 JBL Pulse LED Light Replacement, Outer Casing: passo 6, immagine 2 di 3 JBL Pulse LED Light Replacement, Outer Casing: passo 6, immagine 3 di 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: passo 7, immagine 1 di 2 JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: passo 7, immagine 2 di 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse LED Light Replacement, LED Light: passo 8, immagine 1 di 1
    • Pry off LED light panel using a metal spudger.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 18-6, Blackwell Fall 2016 Membro di USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Membri
13 Guide realizzate
1Commento della guida
Were do I buy a Replacement led strip?
Jalen6988 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,616
