Salta al contenuto principale
JBL Pulse 4 Outside Casing Replacement
Cosa ti serve
  1. JBL Pulse 4 Outside Casing Replacement, Casing Replacement: passo 1, immagine 1 di 1
    • Power on JBL speaker before doing any repairs.
    • Hold the power button for 3+ seconds to power down the device.
  2. JBL Pulse 4 Outside Casing Replacement: passo 2, immagine 1 di 3 JBL Pulse 4 Outside Casing Replacement: passo 2, immagine 2 di 3 JBL Pulse 4 Outside Casing Replacement: passo 2, immagine 3 di 3
    • Remove each rubber end cap using a plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
    • Remove the top by hand.
  3. JBL Pulse 4 Outside Casing Replacement: passo 3, immagine 1 di 3 JBL Pulse 4 Outside Casing Replacement: passo 3, immagine 2 di 3 JBL Pulse 4 Outside Casing Replacement: passo 3, immagine 3 di 3
    • Remove the charging port cover using a plastic pry tool.
    • Remove the two 12.7 mm Phillips #1 screws.
    • Remove the charging port housing from the casing.
  4. JBL Pulse 4 Outside Casing Replacement: passo 4, immagine 1 di 3 JBL Pulse 4 Outside Casing Replacement: passo 4, immagine 2 di 3 JBL Pulse 4 Outside Casing Replacement: passo 4, immagine 3 di 3
    • Disconnect the charging port connector by pulling the connector away from the port.
    • Disconnect the battery level indicator light by pulling the wire away from the lights.
  5. JBL Pulse 4 Outside Casing Replacement: passo 5, immagine 1 di 2 JBL Pulse 4 Outside Casing Replacement: passo 5, immagine 2 di 2
    • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
    • Remove the plastic piece where the 6 screws came out of.
  6. JBL Pulse 4 Outside Casing Replacement: passo 6, immagine 1 di 1
    • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
  7. JBL Pulse 4 Outside Casing Replacement: passo 7, immagine 1 di 3 JBL Pulse 4 Outside Casing Replacement: passo 7, immagine 2 di 3 JBL Pulse 4 Outside Casing Replacement: passo 7, immagine 3 di 3
    • Flip the speaker to the other end.
    • Use a pry tool to pry between the casing of the speaker and the internals.
    • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
  8. JBL Pulse 4 Outside Casing Replacement: passo 8, immagine 1 di 1
    • The casing is now fully detached from the internal components.
    • You can now replace the outer casing of the speaker.
Conclusione
Hank McDonough
Membro da: 03/18/24
377 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 37
Tutti i Tempi: 97
