Salta al contenuto principale
JBL Pulse 4 Charging Port Replacement
Cosa ti serve
  1. JBL Pulse 4 Charging Port Replacement, Charging Port: passo 1, immagine 1 di 1
    • Power off JBL Pulse 4 before starting any repairs.
    • Hold the power button for 3 plus seconds to power down the device.
  2. JBL Pulse 4 Charging Port Replacement: passo 2, immagine 1 di 3 JBL Pulse 4 Charging Port Replacement: passo 2, immagine 2 di 3 JBL Pulse 4 Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove each rubber end cap using an plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap at a time until there is a gap on all sides.
    • The cap can be easily removed by hand.
    • Do not use a metal object or you will scratch the casing or tear the rubber end caps.
  3. JBL Pulse 4 Charging Port Replacement: passo 3, immagine 1 di 3 JBL Pulse 4 Charging Port Replacement: passo 3, immagine 2 di 3 JBL Pulse 4 Charging Port Replacement: passo 3, immagine 3 di 3
    • Carefully remove the charging port cover using a plastic pry tool.
    • Remove the two Phillips head screws.
    • The charging port assembly will be revealed.
  4. JBL Pulse 4 Charging Port Replacement: passo 4, immagine 1 di 3 JBL Pulse 4 Charging Port Replacement: passo 4, immagine 2 di 3 JBL Pulse 4 Charging Port Replacement: passo 4, immagine 3 di 3
    • Pull the charging port assembly out of the casing.
    • Be careful and don't remove the assembly fully to avoid damaging the wires.
    • Carefully disconnect the two wires attached to the assembly.
  5. JBL Pulse 4 Charging Port Replacement: passo 5, immagine 1 di 1
    • Now you can reassemble the speaker reversing the steps provided to take it apart.
Conclusione
Hank McDonough
Membro da: 03/18/24
377 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 64
