Salta al contenuto principale
JBL Pulse 2 Button Circuit Board Replacement
Cosa ti serve
  1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: passo 1, immagine 1 di 2 JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: passo 1, immagine 2 di 2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Button Circuit Board Replacement: passo 2, immagine 1 di 1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Button Circuit Board Replacement: passo 3, immagine 1 di 1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Button Circuit Board Replacement: passo 4, immagine 1 di 2 JBL Pulse 2 Button Circuit Board Replacement: passo 4, immagine 2 di 2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Button Circuit Board Replacement: passo 5, immagine 1 di 3 JBL Pulse 2 Button Circuit Board Replacement: passo 5, immagine 2 di 3 JBL Pulse 2 Button Circuit Board Replacement: passo 5, immagine 3 di 3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Button Circuit Board Replacement: passo 6, immagine 1 di 1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Button Circuit Board Replacement: passo 7, immagine 1 di 2 JBL Pulse 2 Button Circuit Board Replacement: passo 7, immagine 2 di 2
    • Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Button Circuit Board Replacement: passo 8, immagine 1 di 2 JBL Pulse 2 Button Circuit Board Replacement: passo 8, immagine 2 di 2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
where can I buy that part
Wilco Peters - Replica
I love you guys
Davi Dodo - Replica
I need to buy parts
hernzum - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,101
