Introduzione
First, the device will need to be cracked open. After, you will remove the damaged speakers and replace them with new, working speakers.
Cosa ti serve
Turn the device upside down so that the three rubber pads are facing up.
To reassemble your device, follow these directions in reverse order.
Altre 5 persone hanno completato questa guida.
8 Commenti
Where can I buy the replacement speaker?
I join Gןilberto question,can someone attach a link to replacement speakers or tell what is the p/n of the speakers ?
Thanks !
little bit late i just order it after 2 years searching
Do these work as original driver are 8 ohm?
