Salta al contenuto principale
JBL On Stage II Speakers Replacement
Cosa ti serve
  1. JBL On Stage II Speakers Replacement, Cracking the Case: passo 1, immagine 1 di 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Speakers Replacement: passo 2, immagine 1 di 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Speakers Replacement: passo 3, immagine 1 di 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Speakers Replacement: passo 4, immagine 1 di 2 JBL On Stage II Speakers Replacement: passo 4, immagine 2 di 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Speakers Replacement: passo 5, immagine 1 di 3 JBL On Stage II Speakers Replacement: passo 5, immagine 2 di 3 JBL On Stage II Speakers Replacement: passo 5, immagine 3 di 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Speakers Replacement: passo 6, immagine 1 di 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Speakers Replacement: passo 7, immagine 1 di 2 JBL On Stage II Speakers Replacement: passo 7, immagine 2 di 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II Speakers Replacement, The Speakers: passo 8, immagine 1 di 2 JBL On Stage II Speakers Replacement, The Speakers: passo 8, immagine 2 di 2
    • Separate speakers from their slots using a metal spudger.
    • Careful, as this step may cause damage to the device.
  9. JBL On Stage II Speakers Replacement: passo 9, immagine 1 di 2 JBL On Stage II Speakers Replacement: passo 9, immagine 2 di 2
    • Cut the black wire (leading to the speaker you are replacing) with a pair of wire cutters.
    • Cut the red wire (leading to the speaker you are replacing) with a pair of wire cutters.
    • Notice that two black wires and two red wires connect to the speaker, be sure to reattach both wires to the new speaker.
Conclusione
To reassemble your device, follow these directions in reverse order.
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 9-28, Maness Winter 2014 Membro di Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Membri
7 Guide realizzate
8 Commenti
Where can I buy the replacement speaker?
Gilberto Ruiz - Replica
I join Gןilberto question,can someone attach a link to replacement speakers or tell what is the p/n of the speakers ?
Thanks !
Oded Hafuta -
little bit late i just order it after 2 years searching
https://es.aliexpress.com/item/2pcs-For-...
Marcos Jaime - Replica
Do these work as original driver are 8 ohm?
pikachu chuuu -
Thank you for posting this! I need to fix my speakers.
prak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 51
Tutti i Tempi: 14,268
