Salta al contenuto principale
JBL On Stage II Power Jack Replacement
Cosa ti serve
  1. JBL On Stage II Power Jack Replacement, Cracking the Case: passo 1, immagine 1 di 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Power Jack Replacement: passo 2, immagine 1 di 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Power Jack Replacement: passo 3, immagine 1 di 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Power Jack Replacement: passo 4, immagine 1 di 2 JBL On Stage II Power Jack Replacement: passo 4, immagine 2 di 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Power Jack Replacement: passo 5, immagine 1 di 3 JBL On Stage II Power Jack Replacement: passo 5, immagine 2 di 3 JBL On Stage II Power Jack Replacement: passo 5, immagine 3 di 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Power Jack Replacement: passo 6, immagine 1 di 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Power Jack Replacement: passo 7, immagine 1 di 2 JBL On Stage II Power Jack Replacement: passo 7, immagine 2 di 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    Where do I find these speakers
    HighChief - Replica
  8. JBL On Stage II Power Jack Replacement, Circuit Board: passo 8, immagine 1 di 2 JBL On Stage II Power Jack Replacement, Circuit Board: passo 8, immagine 2 di 2
    • Remove the three 1 cm T-10 Torx screws.
  9. JBL On Stage II Power Jack Replacement: passo 9, immagine 1 di 1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. JBL On Stage II Power Jack Replacement: passo 10, immagine 1 di 2 JBL On Stage II Power Jack Replacement: passo 10, immagine 2 di 2
    • Pull the white wire out of the hot glue.
  11. JBL On Stage II Power Jack Replacement: passo 11, immagine 1 di 3 JBL On Stage II Power Jack Replacement: passo 11, immagine 2 di 3 JBL On Stage II Power Jack Replacement: passo 11, immagine 3 di 3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. JBL On Stage II Power Jack Replacement: passo 12, immagine 1 di 3 JBL On Stage II Power Jack Replacement: passo 12, immagine 2 di 3 JBL On Stage II Power Jack Replacement: passo 12, immagine 3 di 3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  13. JBL On Stage II Power Jack Replacement, Power Jack: passo 13, immagine 1 di 3 JBL On Stage II Power Jack Replacement, Power Jack: passo 13, immagine 2 di 3 JBL On Stage II Power Jack Replacement, Power Jack: passo 13, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Turn the device upside down.
    • Solder the back lead of the power jack until the solder melts.
    • Heat the lead until the solder melts.
    • Remove the solder with the desoldering pump.
    • For help with soldering view the iFixit soldering guide
  14. JBL On Stage II Power Jack Replacement: passo 14, immagine 1 di 1
    • Repeat step 13 for the other two leads
  15. JBL On Stage II Power Jack Replacement: passo 15, immagine 1 di 1
    • Remove the power jack.
Conclusione
Replace the power jack with the new jack and resolder the leads. Follow the steps in reverse order to reassemble your device
Cal Poly, Team 9-28, Maness Winter 2014 Membro di Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Membri
7 Guide realizzate
Un commento
Do you know where to find a sound jack for my JBL On Stage? Thanks
David Díaz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,118
