Salta al contenuto principale
JBL L26 Speaker Replacement
Cosa ti serve
  1. JBL L26 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the four 6.4 mm Phillips #2 screws from the front of the speaker.
  2. JBL L26 Speaker Replacement: passo 2, immagine 1 di 1
    • Pull the speaker out of the frame and lay it onto the side.
  3. JBL L26 Speaker Replacement: passo 3, immagine 1 di 1
    • Unlatch the green wire by pulling on the terminal connector and not the wire.
  4. JBL L26 Speaker Replacement: passo 4, immagine 1 di 2 JBL L26 Speaker Replacement: passo 4, immagine 2 di 2
    • Use a small prying tool to pry the terminal connector off of the tap.
    • After you unlatched both edges, pull the black wire out.
  5. JBL L26 Speaker Replacement: passo 5, immagine 1 di 1
    • Get your replacement speaker and connect the green wire by pushing the terminal connector onto the tap.
  6. JBL L26 Speaker Replacement: passo 6, immagine 1 di 2 JBL L26 Speaker Replacement: passo 6, immagine 2 di 2
    • Connect the black wire by attaching the terminal connector onto the tap.
    • Use a clamping tool to clip the edges toward the tap.
    • Be careful not to clamp too hard so you don't damage the tap.
  7. JBL L26 Speaker Replacement: passo 7, immagine 1 di 1
    • Place the new speaker onto the frame and screw the four 6.4 mm Phillips #2 screws back in.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,081
