Introduzione
If your JBL Go will not charge, use this guide to replace the charging port, which will require replacing the motherboard that contains the charging port.
Cosa ti serve
Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
Once the front cover is removed, use a T6 screwdriver to remove the four 9 mm screws on the black cover.
Altre 4 persone hanno completato questa guida.
