Salta al contenuto principale
JBL Flip 5 Outer Case Replacement
Cosa ti serve
  1. JBL Flip 5 Outer Case Replacement, Outer Case: passo 1, immagine 1 di 2 JBL Flip 5 Outer Case Replacement, Outer Case: passo 1, immagine 2 di 2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
  2. JBL Flip 5 Outer Case Replacement: passo 2, immagine 1 di 1
    • Once all the clips are released, you will be able to pull up that edge of the case.
  3. JBL Flip 5 Outer Case Replacement: passo 3, immagine 1 di 1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
  4. JBL Flip 5 Outer Case Replacement: passo 4, immagine 1 di 2 JBL Flip 5 Outer Case Replacement: passo 4, immagine 2 di 2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
Conclusione
UMass Dartmouth, Team 3-5, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-5, Konn Fall 2023
UMASSD-KONN-F23S3G5
4 Membri
5 Guide realizzate
1Commento della guida
just wanted to shout out.. coz i got alot of love for this lil speaker.. then one day it just went cactus on me.. sounded like some beloved neighbour had drilled a hole in it or something.. anyways thanks to this guide i opened it up a saw that a screw had some how come loose and was sitting on the speaker.. was such a simple fix but now its good as new. so thank you muchly.. you just made my day!
moist choice - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 76
Tutti i Tempi: 728
