Introduzione
The outer case replacement or simply removal is a good place to start if you need to replace the outer case or if you need to replace or repair anything inside the JBL Flip 5. Once removed, it's a good idea to check for dirt buildup or anything that might be under the case that might affect device performance.
Cosa ti serve
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Un commento
just wanted to shout out.. coz i got alot of love for this lil speaker.. then one day it just went cactus on me.. sounded like some beloved neighbour had drilled a hole in it or something.. anyways thanks to this guide i opened it up a saw that a screw had some how come loose and was sitting on the speaker.. was such a simple fix but now its good as new. so thank you muchly.. you just made my day!
