Salta al contenuto principale
JBL Flip 5 Buttons Replacement
Cosa ti serve
  1. JBL Flip 5 Buttons Replacement, Outer Case: passo 1, immagine 1 di 2 JBL Flip 5 Buttons Replacement, Outer Case: passo 1, immagine 2 di 2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
  2. JBL Flip 5 Buttons Replacement: passo 2, immagine 1 di 1
    • Once all the clips are released, you will be able to pull up that edge of the case.
  3. JBL Flip 5 Buttons Replacement: passo 3, immagine 1 di 1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
  4. JBL Flip 5 Buttons Replacement: passo 4, immagine 1 di 2 JBL Flip 5 Buttons Replacement: passo 4, immagine 2 di 2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
  5. JBL Flip 5 Buttons Replacement, Speaker: passo 5, immagine 1 di 1
    • Begin by unscrewing the four 9.6 mm-long screws with the Philips #00 screwdriver.
    • Make sure to be careful with the gasket under the edges!
  6. JBL Flip 5 Buttons Replacement: passo 6, immagine 1 di 1
    • Once screws are fully out make sure to carefully pull out so the wires connected don't get damaged.
  7. JBL Flip 5 Buttons Replacement: passo 7, immagine 1 di 1
    • Once you carefully lift up the speaker, gently disconnect the wire that connects the speaker to the motherboard.
  8. JBL Flip 5 Buttons Replacement: passo 8, immagine 1 di 1
    • Once connection has been disconnected you can lift the speaker completely out.
  9. JBL Flip 5 Buttons Replacement, Buttons: passo 9, immagine 1 di 3 JBL Flip 5 Buttons Replacement, Buttons: passo 9, immagine 2 di 3 JBL Flip 5 Buttons Replacement, Buttons: passo 9, immagine 3 di 3
    • The next part needed to remove covers each side and the power and bluetooth buttons in a middle strip along the speaker.
    • The first picture is for reference. That is the part that will be removed.
    • Begin (as shown in the second picture) by unscrewing the two screws (17mm each) with the Philips #00 screwdriver.
    • Then flip the device around and unscrew the other two screws (17 mm each) on the other side just the same.
    • In these pictures the speaker is still in the device. It is best to have already removed it in the Speaker Replacement Guide.
  10. JBL Flip 5 Buttons Replacement: passo 10, immagine 1 di 2 JBL Flip 5 Buttons Replacement: passo 10, immagine 2 di 2
    • Once all the screws are removed, pull the passive radiator bracket on either end off.
    • Set the passive radiator bracket to the side. It is not needed for the buttons replacement.
  11. JBL Flip 5 Buttons Replacement: passo 11, immagine 1 di 3 JBL Flip 5 Buttons Replacement: passo 11, immagine 2 di 3 JBL Flip 5 Buttons Replacement: passo 11, immagine 3 di 3
    • Next you must remove the passive radiator.
    • To do so use the metal spudger to undo the clips holding it down.
    • Once the clips on both sides are removed, you can pull the left and right passive radiators off the device.
    • Both can be set aside. They are not needed for the buttons replacement.
  12. JBL Flip 5 Buttons Replacement: passo 12, immagine 1 di 2 JBL Flip 5 Buttons Replacement: passo 12, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Once the speaker is removed, you must go in through the hole where the speaker was for this step.
    • There you can use tweezers or your fingers to unhook the connection of the buttons board to the rest of the device.
  13. JBL Flip 5 Buttons Replacement: passo 13, immagine 1 di 2 JBL Flip 5 Buttons Replacement: passo 13, immagine 2 di 2
    • Peel the rubber cover off using a metal spudger. It may be very sticky, so you may need to pull hard.
    • Then peel the cover off using your fingers.
  14. JBL Flip 5 Buttons Replacement: passo 14, immagine 1 di 2 JBL Flip 5 Buttons Replacement: passo 14, immagine 2 di 2
    • Again use the spudger to pull the buttons board off.
    • It is glued down, so you must be very assertive using the spudger.
  15. JBL Flip 5 Buttons Replacement: passo 15, immagine 1 di 2 JBL Flip 5 Buttons Replacement: passo 15, immagine 2 di 2
    • In these photos, the buttons board is still on.
    • If only certain buttons are not working it may be appropriate to only replace the buttons board with play/pause and volume up/down. If you are having trouble with the power and bluetooth buttons as well, this step will allow you to replace those.
    • Use the metal spudger to again pull the board containing the power and bluetooth buttons off from the device. It is located next to the strap.
    • It's glued on, use necessary force.
Conclusione
Jackson Tillinghast
Membro da: 10/30/23
303 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 3-5, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-5, Konn Fall 2023
UMASSD-KONN-F23S3G5
4 Membri
5 Guide realizzate
Un commento
I think the newer JBL Flip 5 speakers have updated internals. I received a Flip 5 as a gift years ago and recently had to replace the battery using the tutorials on this website, and it went off without a hitch. I decided to buy another Flip 5 to use the party feature; I accidentally dropped it, and the buttons on the side stopped working. This is when I found out that the internals of my two JBL Flip 5 speakers looked different. This is only my second time trying to repair something on my own, any suggestions would be greatly appreciated.
Jahvier Temple - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 62
Tutti i Tempi: 274
