Introduzione
Is your JBL Flip 4 speaker making abnormal sounds? Does the speaker sound different than when you first got it? If so, your JBL Flip 4's front action speakers may be damaged. This guide will instruct you on removing the damaged speaker so you can later replace it with a new one.
Cosa ti serve
Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
Pry off the cover, beginning with the side without the volume and bluetooth buttons.
Pull off the cover with your thumbs.
Altre 14 persone hanno completato questa guida.
16 Commenti
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Exactly, what is the part number for the internal speaker?
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
