Salta al contenuto principale
JBL Flip 3 Power Circuit Board Replacement
Cosa ti serve
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: passo 1, immagine 1 di 1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: passo 2, immagine 1 di 1
    • Carefully remove outer housing to expose the inner components of the speaker.
    On my Flip 3, there were two Phillips head screws on each end that required removal prior to outer housing removal.
    Skeletwing - Replica
    This is fundamental to specify that this is the SE (Stealth edition). The disassembly is not exactly the same (SE edition is easier)
    cottet cyril - Replica
  3. JBL Flip 3 Power Circuit Board Replacement: passo 3, immagine 1 di 1
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: passo 4, immagine 1 di 1
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
    I have a change point
    ABDULLA P - Replica
    removal of the mainboard is essential if you need to replace the battery for example; it is not shown here
    Dirk Winning - Replica
Conclusione
Altre 14 persone hanno completato questa guida.
James Bianco
Membro da: 02/20/17
151 Reputazione
1 Guida realizzata
USF Tampa, Team S1-G2, Leahy Spring 2017 Membro di USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Membri
17 Guide realizzate
5 Commenti
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - Replica
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - Replica
The title says replacement, and you show only the removal.
Stanimir Nikolov - Replica
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - Replica
Change the battery
odii Emmanuel -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 151
Tutti i Tempi: 29,991
