Salta al contenuto principale
JBL Flip 3 Front Active Driver Replacement
Cosa ti serve
  1. JBL Flip 3 Front Active Driver Replacement, Front Active Driver: passo 1, immagine 1 di 1
    • Remove plastic outer housing using hands or a standard spudger.
  2. JBL Flip 3 Front Active Driver Replacement: passo 2, immagine 1 di 1
    • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
  3. JBL Flip 3 Front Active Driver Replacement: passo 3, immagine 1 di 1
    • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
  4. JBL Flip 3 Front Active Driver Replacement: passo 4, immagine 1 di 1
    • Remove the 3-pin connector from motherboard.
Conclusione
Altre 14 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Leahy Spring 2017 Membro di USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Membri
14 Guide realizzate
7 Commenti
where did you source the drivers from?
Rashid Saad Siddiqui - Replica
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - Replica
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - Replica
i need help getting the front speakers only where would i get them???
brian ortiz - Replica
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 152
Tutti i Tempi: 17,675
