Salta al contenuto principale
JBL Flip 2 Speaker Replacement
Cosa ti serve
  1. JBL Flip 2 Speaker Replacement, JBL Flip 2 Outer Case Disassembly: passo 1, immagine 1 di 2 JBL Flip 2 Speaker Replacement, JBL Flip 2 Outer Case Disassembly: passo 1, immagine 2 di 2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
    From where i can buy these speakers?
    Nitin Z - Replica
    First thing I did was rip the wire from the NFC chip! Luclily I don't need it as I only ever use my flip with my iPhone.
    Ken McMahon - Replica
  2. JBL Flip 2 Speaker Replacement: passo 2, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
  3. JBL Flip 2 Speaker Replacement: passo 3, immagine 1 di 3 JBL Flip 2 Speaker Replacement: passo 3, immagine 2 di 3 JBL Flip 2 Speaker Replacement: passo 3, immagine 3 di 3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
    what if the wire DID disconnect? could s.o. add a detail pic of exactly where the cables connect on the chip?
    dfhdrt34f3t - Replica
    Need the real name of the NFC chip, caus i broked and need to change
    Thanks
    Daniel Huot - Replica
    Need the real name of the NFC chip, cause i broked and need to change
    Thanks
    My chip reads WN-3088 20130912
    Thomas Blanchard - Replica
  4. JBL Flip 2 Speaker Replacement: passo 4, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 4, immagine 2 di 2
    • Peel the black rubber piece from one end to the other.
  5. JBL Flip 2 Speaker Replacement: passo 5, immagine 1 di 3 JBL Flip 2 Speaker Replacement: passo 5, immagine 2 di 3 JBL Flip 2 Speaker Replacement: passo 5, immagine 3 di 3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
    Tutto molto interessante.
    Ma la cosa più importante è:
    Dove acquistare gli altoparlanti ??
    terlizzigianfranco75 - Replica
  6. JBL Flip 2 Speaker Replacement: passo 6, immagine 1 di 3 JBL Flip 2 Speaker Replacement: passo 6, immagine 2 di 3 JBL Flip 2 Speaker Replacement: passo 6, immagine 3 di 3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
  7. JBL Flip 2 Speaker Replacement: passo 7, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 7, immagine 2 di 2
    • Expand the metal casing and carefully slide it off the speaker.
  8. JBL Flip 2 Speaker Replacement: passo 8, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 8, immagine 2 di 2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
  9. JBL Flip 2 Speaker Replacement: passo 9, immagine 1 di 3 JBL Flip 2 Speaker Replacement: passo 9, immagine 2 di 3 JBL Flip 2 Speaker Replacement: passo 9, immagine 3 di 3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
    For easier removal warm the tape up with a hair dryer. It tears apart very easily.
    hale1730 - Replica
    Keeping the tape intact is impossible - I replaced it with electrical tape.
  10. JBL Flip 2 Speaker Replacement: passo 10, immagine 1 di 3 JBL Flip 2 Speaker Replacement: passo 10, immagine 2 di 3 JBL Flip 2 Speaker Replacement: passo 10, immagine 3 di 3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  11. JBL Flip 2 Speaker Replacement: passo 11, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 11, immagine 2 di 2
    • Use the black spudger to disconnect the speaker cord from it's socket.
  12. JBL Flip 2 Speaker Replacement: passo 12, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 12, immagine 2 di 2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
    What is the function of auxi. Wire
    Debabrata Paul - Replica
    When you plug in the audio jack it goes to the motherboard, the amplifier and then to the wire directly to the speakers.
    Jose Palacios - Replica
  13. JBL Flip 2 Speaker Replacement: passo 13, immagine 1 di 1
    • Carefully remove the cable connecting the control chip to the motherboard.
    What's the name of the cable connecting the control chip to the motherboard
    Jose Cabello - Replica
    I want motherboard control chip
    moneykandan110 - Replica
    connecting the control chip kitne ka hai
    Niraj Kumar - Replica
  14. JBL Flip 2 Speaker Replacement: passo 14, immagine 1 di 2 JBL Flip 2 Speaker Replacement: passo 14, immagine 2 di 2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
    If you can“t see a connector here , you have an earlier version of Flip2 - the connector is on the backside and requires a different battery - see the comment at the end of the feature
    Klaus - Replica
  15. JBL Flip 2 Speaker Replacement: passo 15, immagine 1 di 1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
  16. JBL Flip 2 Speaker Replacement, Speaker: passo 16, immagine 1 di 1
  17. JBL Flip 2 Speaker Replacement: passo 17, immagine 1 di 1
    • Remove the metal bar that was held in place by the screws.
  18. JBL Flip 2 Speaker Replacement: passo 18, immagine 1 di 1
    • Unscrew the the other four 7.0 mm Phillips #1 screws around the speakers.
  19. JBL Flip 2 Speaker Replacement: passo 19, immagine 1 di 1
    • Gently remove the speakers from the slots.
    Brdtha please gi you 2 skikar
    Raj Raju - Replica
  20. JBL Flip 2 Speaker Replacement: passo 20, immagine 1 di 1
    • Check the speaker connections to see they are loose.
    • If the connections are loose, they will need to be re-soldered. For information on how to do so, click here.
    • If speakers are still not functioning, then replace them.
  21. JBL Flip 2 Speaker Replacement: passo 21, immagine 1 di 1
    • Remove the connections from the speakers.
    • Replace the old speakers by soldering the four wires onto each connector of the new speakers.
    • Check out IFixit's official soldering guide for help with these special projects.
    • Soldering iron will be very hot.
    • If you disassembled the Flip 2 to replace the speakers, you'll need to find suitable replacements. The Dayton Audio CE40P-8 is a 1.5" diameter, 1" deep, 8 ohm speaker that works well, as explained in this video.
    Where to buy these replacement speakers? Pls provide a website or link and enable me to purchase and repair my torn speakers.
    Jayanth A - Replica
    the guide tells you which speaker to buy on the final step
    demogorgo -
    Hi, where can I buy a new speaker for replacement. The old one was damage. It needs to to be replace. Id ratger want it repair than buying. Do I need to buy it to JBL repair service center?
    Miu - Replica
    the guide tells you which part to buy on the final step
    demogorgo -
    https://www.highlight-led.de/en/mini-bas...
    This should work. Even the bracket seems to be right.
    Balazs Soos - Replica
    On my JBL FLip 2 speaker’s label says:
    F40N8C
    HS0009-0001061
    8 Ohm
    PS2-150HB
    As I got it is 40mm (1,5 inch) diameter.
    This label is quite similar to this brand: GHXamp
    Aleksandr A - Replica
    On my side, I ordered the speaker PUI Audio ASX04008-R from Digikey (668-1563-ND), which is the right diameter. It is rated 3W with max 5W. The down side of this speaker is the missing center cone. Hoverver, I have been able to retreive the cone from the defective speaker and transfer it. The new speaker has an adhesive ring that allow to do this. Since the new speaker doesn't have the flanges, I have cut, with a cutter, the ones from the old speaker and be able to hold the new speaker in place. To make all my test, I have used the iPhone app "Tone Generator" made by TMSOFT which allow me to select any frequency and use the balance control to compare between the right and left speaker.
    The end result is very good.
    Pierre Talbot - Replica
    Amazon Mitteilung:
    6,49 $ (3,25 $ / Stück)
    Dieser Artikel kann nicht an den von dir ausgewählten Zustellungsort versendet werden. Bitte wähle einen anderen Zustellungsort aus.
    In Deutschland nicht erhältlich.
    Michael Friedrich - Replica
Conclusione
Altre 28 persone hanno completato questa guida.
Jonathan Wear
Membro da: 02/09/16
1.220 Reputazione
5 Guide realizzate
USF Tampa, Team 11-2, Cheng Spring 2016 Membro di USF Tampa, Team 11-2, Cheng Spring 2016
USFT-CHENG-S16S11G2
4 Membri
8 Guide realizzate
18 Commenti
Where to buy the speakers for JBL flip 2! Pls post it's urgent!
Jayanth A - Replica
Since I wasn’t in the US and shipping cost from the Dayton speakers were prohibitvely, I ended up finding the speakers form China. The upside is that they are easier to install, since you dont have to cut down the lateral support, the downside is that they are 6 Ohms and have a lower quality. Though I worked for me.
https://pt.aliexpress.com/item/100500235...
Rafael Augusto Prado Alves -
Can somebody send a link for the replacement speakers pls.
Jayanth A - Replica
Hey, maybe you have the link? :)
adielhadad59 -
What is the size and ohmz and watts of the speaker?
Sekar Kalimuthu - Replica
8ohms 40 watts and 1 inch I think. I been searching where to buy these as well. The rings are separated on mine
1brandonkalo -
En donde puedo comprar las speaker
Emanuel Perez - Replica
Instructions are very helpful and I thank you . However I now am finding it impossible to find the replacement speakers for the flip 2 so it appears the de-construction was a waste of time! Such a shame as the unit is working fine but for a buzzy speaker.
Brian Myles - Replica
Can anyone provide a link to buy speakers please
ïTz_ rïçky - Replica
Doe anyone know if there are any alternative for the speakers? Or the ref code for them?
Igor Bayle - Replica
I need to replace my speaker from my jbl flip ..how can I buy them
jonessangeeta - Replica
I just added a video with details on a good replacement speaker option that I used with great success. The Flip 2 sounds like new. Here’s a link to the speakers that I purchased:
https://www.parts-express.com/dayton-aud...
Sean Hughes - Replica
I want to buy replacement speakers. Can someone share ebay.in
Its not available for indian locations.
Karam Sahu - Replica
My flip2 won’t charge
bones1958 - Replica
If someone can help me to find the replacement battery? Thanks
Jimmy Tsai - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 71
Ultimi 30 Giorni: 420
Tutti i Tempi: 40,115
