Salta al contenuto principale
JBL Flip 2 Outer Case Disassembly
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. JBL Flip 2 Outer Case Disassembly, JBL Flip 2 Outer Case Disassembly: passo 1, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly, JBL Flip 2 Outer Case Disassembly: passo 1, immagine 2 di 2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
  2. JBL Flip 2 Outer Case Disassembly: passo 2, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 2, immagine 2 di 2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
  3. JBL Flip 2 Outer Case Disassembly: passo 3, immagine 1 di 3 JBL Flip 2 Outer Case Disassembly: passo 3, immagine 2 di 3 JBL Flip 2 Outer Case Disassembly: passo 3, immagine 3 di 3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
  4. JBL Flip 2 Outer Case Disassembly: passo 4, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 4, immagine 2 di 2
    • Peel the black rubber piece from one end to the other.
  5. JBL Flip 2 Outer Case Disassembly: passo 5, immagine 1 di 3 JBL Flip 2 Outer Case Disassembly: passo 5, immagine 2 di 3 JBL Flip 2 Outer Case Disassembly: passo 5, immagine 3 di 3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
  6. JBL Flip 2 Outer Case Disassembly: passo 6, immagine 1 di 3 JBL Flip 2 Outer Case Disassembly: passo 6, immagine 2 di 3 JBL Flip 2 Outer Case Disassembly: passo 6, immagine 3 di 3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
  7. JBL Flip 2 Outer Case Disassembly: passo 7, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 7, immagine 2 di 2
    • Expand the metal casing and carefully slide it off the speaker.
  8. JBL Flip 2 Outer Case Disassembly: passo 8, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 8, immagine 2 di 2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
  9. JBL Flip 2 Outer Case Disassembly: passo 9, immagine 1 di 3 JBL Flip 2 Outer Case Disassembly: passo 9, immagine 2 di 3 JBL Flip 2 Outer Case Disassembly: passo 9, immagine 3 di 3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
  10. JBL Flip 2 Outer Case Disassembly: passo 10, immagine 1 di 3 JBL Flip 2 Outer Case Disassembly: passo 10, immagine 2 di 3 JBL Flip 2 Outer Case Disassembly: passo 10, immagine 3 di 3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  11. JBL Flip 2 Outer Case Disassembly: passo 11, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 11, immagine 2 di 2
    • Use the black spudger to disconnect the speaker cord from it's socket.
  12. JBL Flip 2 Outer Case Disassembly: passo 12, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 12, immagine 2 di 2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
  13. JBL Flip 2 Outer Case Disassembly: passo 13, immagine 1 di 1
    • Carefully remove the cable connecting the control chip to the motherboard.
  14. JBL Flip 2 Outer Case Disassembly: passo 14, immagine 1 di 2 JBL Flip 2 Outer Case Disassembly: passo 14, immagine 2 di 2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
  15. JBL Flip 2 Outer Case Disassembly: passo 15, immagine 1 di 1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
Conclusione
John Hornbeck
Membro da: 02/09/16
225 Reputazione
1 Guida realizzata
USF Tampa, Team 11-2, Cheng Spring 2016 Membro di USF Tampa, Team 11-2, Cheng Spring 2016
USFT-CHENG-S16S11G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 404
