Salta al contenuto principale
JBL Everest Elite 300 Headband Cushion Replacement
Cosa ti serve
  1. JBL Everest Elite 300 Headband Cushion Replacement, Headband Cushion: passo 1, immagine 1 di 1
    • Extend the headphone.
  2. JBL Everest Elite 300 Headband Cushion Replacement: passo 2, immagine 1 di 3 JBL Everest Elite 300 Headband Cushion Replacement: passo 2, immagine 2 di 3 JBL Everest Elite 300 Headband Cushion Replacement: passo 2, immagine 3 di 3
    • Bend the hinge slightly, then remove the two .5 mm screws with a Phillips #000 screwdriver.
    • This will be repeated on both sides.
  3. JBL Everest Elite 300 Headband Cushion Replacement: passo 3, immagine 1 di 1
    • Slide down the "Elite 300" tab.
    • Repeat on both sides.
  4. JBL Everest Elite 300 Headband Cushion Replacement: passo 4, immagine 1 di 2 JBL Everest Elite 300 Headband Cushion Replacement: passo 4, immagine 2 di 2
    • Use a SIM tool to push pin fully through and out.
    • Repeat on the other side.
  5. JBL Everest Elite 300 Headband Cushion Replacement: passo 5, immagine 1 di 2 JBL Everest Elite 300 Headband Cushion Replacement: passo 5, immagine 2 di 2
    • Go along the edges with the pick, and pull up, taking off the band.
  6. JBL Everest Elite 300 Headband Cushion Replacement: passo 6, immagine 1 di 3 JBL Everest Elite 300 Headband Cushion Replacement: passo 6, immagine 2 di 3 JBL Everest Elite 300 Headband Cushion Replacement: passo 6, immagine 3 di 3
    • After fully taking off the band, you are now ready to insert in the new band.
    • When placing in the new headband, line up the holes as shown in image 2.
    • The headband is difficult to replace, however after lining up the holes, the headband will snap into place. Push into the plastic and push away from you. A click will happen indicating it attatching.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 74
