Introduzione
This guide is to help you replace the speaker housing on a JBL Clip 3 speaker.
If the original speaker housing on your JBL Clip 3 is damaged or worn, you can use this guide to replace it, improving both the look and performance of the speaker.
Note: Before beginning, make sure to power off the JBL Clip 3, and disconnect it from any external power sources.
Cosa ti serve
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Altre 3 persone hanno completato questa guida.
